Check Engine: Code 300, 302, 304 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-13-2006, 02:22 AM Thread Starter
Date registered: Jun 2003
Hey guys,
Got 3 check engine codes today out of nowhere. at first i thought it was b/c of K&N and new MAS but when i went to search codes it showed "Misfire damages at TWC, Misfire damages at TWC Cylinder 2, " " " Cylinder 4. I went to clear the codes, and then turned on the car and it runs great now. I dunno if it was just a one time fluke. When it happened i just got in car and cranked it and it started REALLY rough for some reason, was surging and etc. but after a while it was driving fine. Was this just a one time fluke? Also what does TWC mean? thx
omeyhomey is offline
post #2 of 6 (permalink) Old 09-13-2006, 02:29 AM Thread Starter
after checking multiple forums i found out it could be either bad spark plugs, bad coils (most likely not the case) or dirty MAS but i just put new one in but it has K&Ns. Gonna use my alcohol cleaning method to see what I can do. for now codes are cleared i'll see how long it takes before they come back
post #3 of 6 (permalink) Old 09-13-2006, 06:38 AM
L8braker's Avatar
Date registered: Jan 2003
Vehicle: 01 E55, 01 ML320, 04 TSX, 06 Silverado
K&N's don't mix well with Benz's. I had multiple issues with my CLK430 and the oil build up on the MAF. It wouldn't take more then a day or two to ruin a brand new MAF.
Try Electrical Cleaner, it won't leave any residue.
L8braker is offline
post #4 of 6 (permalink) Old 09-13-2006, 09:43 AM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 5 Post(s)
TWC means Three Way Catalytic . I think your converter is not taking up and realeasing 02 in the qualities required to convert engine emission gases to water and carbon dioxide. and the cat may also have lost some of it's oxygen storage capability. Try not to mess with your MAF, 02 sensors if your are not getting a "check engine" warning or other electrical issue ie; spark plugs wire. Have it check by a certified Tech it seems like youve been getting error codes everytime.
Take care & enjoy the ride,
Joseph
JOE55 is offline
post #5 of 6 (permalink) Old 09-13-2006, 01:53 PM Thread Starter
I cleaned my other MAS in alcohol gonna see how it turns out. Gonna re-install today. i'll let u know how it turns out.
post #6 of 6 (permalink) Old 09-13-2006, 02:42 PM
JOE55's Avatar
Vehicle: E55 ///AMG
Quoted: 5 Post(s)
I thought you have a new sensor?
JOE55 is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > AMG W210 E50 , AMG E55
User Tag List
Check engine light on, code P0200 on 97 E 300 diesel crid W210 E-Class 28 05-07-2014 10:45 AM
check engine code empirical R129 SL Class 0 03-30-2006 01:49 PM
check engine code 1170 JoebenzSclass W140 S-Class 0 02-23-2006 05:57 PM
302 / t5 engine /trans swap jeff7133 W201 190 Class 5 02-09-2006 03:04 AM
code for check engine Young Blood R129 SL Class 8 07-24-2005 09:26 PM
